Accord
Sponsored by:
Sponsored by:
apex-i VAFC controller
Old 05-07-2003, 11:44 PM
hottieaccordrcr
hottieaccordrcr's Avatar
Default apex-i VAFC controller
i need to know if anyone know's how to wire up a apex-i VAFC controller in a 96 accord ex if so i need the pin numbers and colors of ALL the wires i need to hook it up and if i need to modify anything
Old 05-08-2003, 07:30 AM
BlackChrome
E46/CD5
BlackChrome's Avatar
If you go to APEXi's site, I believe the VAFC doesn't work with the F22's VTEC. You might want to get a SAFC instead.
http://www.apexi-usa.com/tech.asp
Q: VAFC: Will the VAFC work on 4 cyl. Accords?
A: No. The VAFC will not work correctly on 4 cyl. Accord models. 4 cylinder Accords incorporate a slightly different method of VTEC control causing the engine to hesitate at approx. 5000 RPM when the VTEC engagement point is changed. The VTEC AFC will work correctly on 6 cyl. Accords.
Old 05-08-2003, 08:03 AM
decibel_dj
decibel_dj's Avatar
i heard it works just fine and has reported 8whp of gain in the 5th gen EX.. last i heard i bought one but never installed it was waiting on a h22 setup but thigns changed
