H22 in 92 accord ECU wiring, PLEASE HELP!!
Old 05-07-2003, 09:04 AM
Sleeper00
Sleeper00's Avatar
Default H22 in 92 accord ECU wiring, PLEASE HELP!!
i just got the h22 motor for my 92 accord, i need to know how to add wires to the ecu, i dont know where is all the vtec wires at, can someone post any pictures of the engine to show where i have to wire from the engine to the ecu or draw a picture or something that show where the wires go, i really need it, any info will help, thankx ppl
Old 05-07-2003, 11:24 AM
TJCCARDCO
TJCCARDCO's Avatar
u dont know how to add wires to the ECU? Get a helms manual. It will tell you where the VTEC is supposed to go, you have to run it from the engine bay to the ECU - you also have to add knock sensor, vtec pressure switch, vtec solenoid, ehh and something else. YOU SHOULD HAVE DONE RESEARCH BEFORE YOU DID THE SWAP.
Old 05-07-2003, 08:22 PM
Sleeper00
Sleeper00's Avatar
i did research b4 i got the h22, i know i need to add wires to the ecu, my problem is where do i run the wires from? and the stock accord wire harness connectors wont fit on h22 engine harness connectors. and accords connectors r some on the left side and some on the right side, h22 engine connectors r on the right sides, can someone help me please
Old 05-08-2003, 09:54 AM
Sleeper00
Sleeper00's Avatar
NEED HELP PLEASE!!!
Old 05-08-2003, 01:04 PM
TJCCARDCO
TJCCARDCO's Avatar
you have to re-route the wiring harness to the proper spots on the engine.
GET A HELMS MANUAL. christ.
