starting problems
starting problems
When i try to first start my Legend (90) I have to turn it over for a long time before it kicks on. Can anyone explain why it does this and anyway i can fix this problem.
THanks
~rc
THanks
~rc
If you got code 8 stored in your ecm memory i'm going through the exact same thing on my girlfreinds 90 legend. I'm in the process of figuring it out, I just don't have the time to spend on it right now. I'm pretty sure i'm going to find the problem either in the tdc sensor or the crank angle sensor. Only problem is neither of them or something you just replace and say oh well if it didn't work. One cost 100 bucks and requires pulling the timing belt off the other one is prolly going to cost over 200 dollars.
