can i prep my car myself?
BOOM goes the dynamite!
i'm fairly certain you can. it would make it cheaper. i would talk to the body shop you're thinking about taking it to, and asking them. you'd probably just have to sand it down, fill any holes you wanted to do, then primer it. find out how many coats you'd need and if you'd have to do any sanding after primering it. i'm thinking about doing it myself too, though i may try to paint it myself as well.
apply 3 good coat of primer then wait at least 3 hrs to dry. then spray a black guide coat ( meaning is spray a mist coat over the primer spot) then wet sand with a sanding block. use 400 grits paper. taking out the black guide coat then until smooth.. hope that help
it depend on the condition of the car. Are u applying body filler? Or just want to primer the whole for a paint job? If u applying body filler then i have to sand it down to the metel then straight the dent out then apply body filler then sand it down... then primer it.. it really depend on what u doin to it let me know thanks jimmy
painting side moldings?
i was wondering how i should paint the side moldings.. what sandpaper should i use to sand it? what kinda primer? wut kinda paint? (can i use spray can paint?)
used scuff agent and grey scuff pad on the molding.. i depend on the spray can if u sprayin black it's ok... or u can sand it down with 500 grit then 600.. same primer u used for ur car hope that help jimmy
