| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
How hard is it to replace transmission cover?
| Sponsored Links | ||
#2 |
Keeping the faith...
I'd like to get clarification on one thing..
Did the case of the tranny actually split? Or did a mounting flange bust off in the wreck? Most of the time, trans work isn't DIY. They can be a real pain to reassemble, plus I'm concerned over the integrity of the tranny given the damage it sustained. I'd be pragmatic about it and replace the tranny [if the case has actually split or has a hole]
david :: supermoderator :: HAN Integra FAQ: Borderline antique, but still useful. |
#3 |
The right side cover has the front most rounded corner knocked off. The main case is fine but the right side cover that has a hole in it about the size of a dime. I've taken the fender off and the case is easy to reach, I just want to make sure that there is nothing that will "spring" out. If you say that to replace the cover is more difficult than it looks then I will let a tranny shop do it.
I put a piece of tape over the hole during the repair and their has been no leakage while test driving, but tape is certainly not a long term solution. I'm not concerned about the longevity of the trans as I have so little in the car that if the trans fails I can either part it out or sell the car as is. |
#4 |
Yeah, the tape certainly isn't a good long-term solution. Because of the alignment of the layshafts and hydraulic conduits within the case, if the impact was strong enough to put a hole in the case, I would question two things: where that broken piece went and what other internal damage the trans may have sustained... Just my 2 ˘.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
