can someone tell me times and power
i have a 91 accord dx stick
header intake exhaust, wires, plugs
can someone tell me about what amount of hp i have?
what it would run in the 1/4?
and zero to sixty speed?
for hp dont you just take off 10%
stock hp is 125.
stock hp is 125.
Im So JDM
Nothing special in 0-60 and prob. same with 1/4 mile. You get better high speed performance from those parts. I have same thing on my 96 accord.
Probally have HP around 110ish? idk...
un-Touch'd krew
Re: can someone tell me times and power
stock hp is 125.
stock hp is 125.
Dyno the car because that is the only accurate way to get a number out of it.
cx power!
Location: berkeley, ca --> la, ca representin' tha 510&626
i wouldnt want to dyno my stock accord. it would make me very :wtc: although ive seen dynosheets of a stock 96 ex auto put down 123hp@wheels.
Guest
Posts: n/a
the stock automatic LX puts down about 110hp from 125 (not too bad), as I recall it. As for your 1/4 time, etc, you have to go run the car to find out . EVERY car is different, even with the same exact mods and the same motor, miles, mantinance routines, etc, can effect power in the long run. Also, for what you have, at very best you'll run a mid 16. Don't expect much out of bolt-on motors unless they are swapped ;o)
