Accord
Sponsored by:
Sponsored by:
Change blicker light in dash...?
Old 04-08-2003, 12:06 PM
mrbrace
Goldenchild
mrbrace's Avatar
Default Change blicker light in dash...?
Does anyone know if when you take off the tach and the speedometer if you can change the bulb color from green to blue? On a 94 Accord that is
Matt
Old 04-08-2003, 12:11 PM
slpycd7
H22 fo lyfe!
slpycd7's Avatar
put blue transparent tape over the signal light, cuz i believe the bulb is white not green.
Old 04-08-2003, 04:34 PM
SumAccordGuy94
Older Honda Fanatic
SumAccordGuy94's Avatar
the bulb is clear... then there is a color filter used just behind the tinted "arrow" piece. You can replace that color filter very easily... just take the cluster out of the car, remove the front clear piece and take the gauge trim off... you'll see the color filters on the gauge assembly.
Old 04-08-2003, 04:37 PM
RY2K
5 speed
RY2K's Avatar
if you wanted to go crazy you could change the bulb to a blue LED
but what SumAccordGuy94 said is fine
i did this about a month ago
and when my friends are in the car they just jockin' it hardcore
Old 04-09-2003, 05:07 AM
Matt86
vtec ownz j00
Matt86's Avatar
Anyone have instructions on removing the 5th gen's cluster?
Old 04-09-2003, 11:18 AM
Tenzo
Mazada RX8 *drools*
Tenzo's Avatar
Its a bitch =)
Get haynes manuel out and go to town on all the screws. No one is going to be able to give a detailed enough discription where you would find all the screws.
have fun, after the 1st time you don't have to put "all" the screws back in so its not as hard the 2nd time.
Old 04-09-2003, 12:52 PM
AccordCutie
AccordCutie's Avatar
Cryogen97's site comes in handy
http://www.andrews.edu/~johnsonm/
Go to How-To and then to Installing Indiglos, and it has instructions on removing the dash to get the the cluster.
