Painted moldings, 1 year later look like crap
Old 04-06-2003, 02:38 PM
BenB
Must stay awake
BenB's Avatar
Default Painted moldings, 1 year later look like crap
Whats the deal .. I used a primer with a flex agent in it and I can't remember if the factory color paint I got had it though.
But now it looks like crap. Most parts are dull and paint gone down to the rubber.
Some parts still look okay but thats maybe 5 percent.
Was there a trick to it that I didn't know about?
Old 04-06-2003, 04:02 PM
I Like JDM
JDM Spec Tuner
I Like JDM's Avatar
Im assuming u sanded it down before adding the flexing agent.
I sanded it down, added flexing agent, then painted it 4 coats plus 3 coats of clears...still good 2 years later.
Old 04-06-2003, 04:09 PM
Nightshade
un-Touch'd krew
Nightshade's Avatar
Painting mouldings is one of the biggest pains in the ass.
Its all in the prep work no matter how you look at it and if you don't do good prep work it shows up.
Try it again and take your time doing it. We did a friend of mines mouldings and it took us several times to get it right..ended up pulling them off and doing it over the course of a day and a half to make sure everything set up exactly right.....looks perfect a year and a half later.
Oh and the mouldings were black on a white car and thats the hardest color to get to work right because the black bleeds through all the time.
Old 04-06-2003, 04:45 PM
JJJ784
No Soup For You!
JJJ784's Avatar
bulldog adhesive promoter
Old 04-06-2003, 05:17 PM
EurAznBoi
EurAznBoi's Avatar
Default Re: Painted moldings, 1 year later look like crap
how many coats of primer and clear coat as well as the color-matched paint did you use? The time in between coats is also important as well as the climate outside. Sanding down the moldings is also essential for the moldings to stick.
Old 04-07-2003, 01:03 PM
accordfreak
accordfreak's Avatar
mine was painted 2 years ago and it still looks good
i posted the diy a year and a half ago on here haha
Old 04-08-2003, 09:35 AM
BenB
Must stay awake
BenB's Avatar
Default Re: Re: Painted moldings, 1 year later look like crap
If I remember, I think I did 2 coats of primer...and 3 coats of paint, and I could only put on 2 light coats of clear coat because if I put anymore, it would cause the paint to crack in to tiny pieces. I couldn't figure out why. I redid them a couple of times before they wouldn't crack.
Old 04-08-2003, 10:55 AM
EurAznBoi
EurAznBoi's Avatar
Default Re: Re: Re: Painted moldings, 1 year later look like crap
I think you should have used 2 more coats of paint and 1 more coat of clear coat. That's what I did and so far my moldings have been flawless for 1 year so far.
Oh yah, did you sand down the moldings before you painted them?
Old 04-08-2003, 11:21 AM
BenB
Must stay awake
BenB's Avatar
Default Re: Re: Re: Re: Painted moldings, 1 year later look like crap
Yeah I sanded them down. 1 more clear coat would have been nice, it just seemed when I added more it would crack the paint... I will probably try and find a pair of white moldings, or some chrome (silver plastic) and paint those white. Probably be a lot easier since they don't warp with the change of seasons. But then there is the up keep so ones already white would be nice.
Old 04-08-2003, 11:55 AM
accordfreak
you don't use PRIMER
