Acura TL 2005 Wheel Alignment
Old 06-22-2010, 06:01 AM
rufusforus
rufusforus's Avatar
Default Acura TL 2005 Wheel Alignment
I have an Acura TL-2005. In the last 6 months I've had to get my alignment realigned about seven or more times . It is causing my tires to wear extremely fast. Ive taken it to the dealership and firestone. Neither of them can find a problem. Is anyone familiar with my problem and if so, is there are any TSB's on alignment problems or a solution. Please let me know. Thank you.
Old 06-29-2010, 09:39 PM
Spec R
Spec R's Avatar
start looking for any destroyed/worn bushings. things will read fine while the car is NOT in motion, but get it on the road and those bushings can throw all sorts of haywire in the alignment
DB Squad
Integra Forum Moderator
Old 07-03-2010, 01:56 PM
cruzalekz
cruzalekz's Avatar
my question to you, is the allignment printout all green? does the steering wheel goes straight?
if it does, its just the way you drive thats affecting your tires or you are using an aftermarket wheels with low profile tires.
