'93 Honda Legend - ALB light
Hope you can help me..
Recently bought a Legend '93 Sedan. After a couple of minutes driving the ALB light comes on and stays on.
Can someone tell me the following :-
- does this model use ALB2 system
- where do I find the diagnostic terminal
- will the diag work when the ALB light doesn't come on unless the car is moving
- On another topic can anyone tell me if it uses R12 or R134 A/C coolant ?
Thanks lots
RH
Thanks lots
RH
Heeyyy, mine did that when the brake fluid was low...there are TWO brake reservoirs, one on each side..make sure they are BOTH full..and check the clutch fluid too(runs on brake fluid also).
