| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
5 speed
resistors for LEDs question
| Sponsored Links | ||
#2 | |
Sinner
wattage is a measurement of power. the wattage rating on a resistor is basically how many watts/milliwats it can safely dissipate as heat. i'd go with the 1/2 watt ones. better to be safe than sorry.
Quote:
#3 |
Whats the equation you used to figure this out?
#4 |
I usually use 220 ohm.....but da jus me.
If anything is to get screwed up by using the wrong resistor, it would be the LED itself and nothing else....feel free to correct me if im wrong
1991 Honda Accord LX 5-Speed http://www.superford.org/registry/ve...ondasig003.jpg |
#5 | ||
Sinner
Quote:
Quote:
#6 | ||||
5 speed
Quote:
Quote:
Quote:
![]() Quote:
check out the web page it's explained really well http://www.igd4u.com/modules.php?op=...=article&sid=2 |
#7 | ||
Sinner
Quote:
i knew that.... it's been a while since i used it thoughhere's the extended equation to calculate power in a circuit. ![]() using W=E^2/R you'll see that the 1/4 watt resistors won't cut it. and a burning resistor don't smell good at all.
Quote:
#8 | |
5 speed
Quote:
my car smells like cucumber melon, and a burnt resistor would not be very
#9 | ||
Sinner
Quote:
Quote:
#10 |
I go with the 220 ohms with the 3.5v. It's the best combo 4 leds and resistors.
#11 | |
Quote:
#12 |
uh i am too lazy to do the calculations but use Ohms law V=IR and use the power one P=VI where v is voltage, I is current and r is resistance....also u might have to do simple algebraic manipulations but it should just take a few seconds to figure it out
1993 honda prelude si w/270k miles+ |
#13 | |
BOOST GOD
Quote:
we already covered Ohm's law of E=IR but we left out his law for power: P=IE So reading your pic of the LEDs it says that can handle 3.7v at 20mA 3.7v * .020A == .074W 5v * .020A== .1 W 1/4 watt == .25w, so a quarter watt will more than cover you. Now where are you going to get your (max 4.5v) from? Since your car runs a 12v system? If you decide to just run the LEDs off 12v: E / R == I 12v / 470ohm == .025A == 25mA Which appears to be 5 mA over the LEDs rated limit. You can generally get away with overvolting stuff, it's amperage (current) which will cause problems. So I guess if you wanted to use 12 volts, without exceeding the reccomend current rating, you'd do something like this: E/R==I => E/I==R E / I == R 12v / .020A == 600ohms Nobody makes a 600 ohm resistor. So looking at the equation: E/R==I You don't want "I" (current) to go up. So you want your denominator (R) to go be larger. (denominator gets bigger, product gets smaller). Your resistor choices are: 560 - 600 = -40 ohms from target 680 - 600 = +80 ohms from target. I lied, I just took 2 1.2kohm resistors (1200ohm) resistors, hooked them up in parallel, and that was exactly 600 ohms. I took some measurments: 600ohms at 12 v was drawing .015Amps of current 470ohms at 12v was drawing .020Amps of current. theoretically 12v at 600ohms shold draw .020 amps 12v at 470ohms should draw .025 amps However, all resistors have 10% margin of error (gold band), or 5% margin of error (silver band). So the LED manufacturers, I'm sure accounted for that using standard industry design practices, when rating their LED (at .020amps). ![]() Here we see the LED running off of 12v, on the left through a 470ohm load, on the right through a 600ohm load. What does that all mean? You can use a single 470ohm 1/4 resistor, no problemo. 1/2 watt will not give you any extra protection. Feel free to ask any question (except "why did you make this post so long" )-PHiZ |
#14 | |
Stage 3 Modified
so yea after you guys lost me with all that math stuff,...what are you guys using LED lights for??? and post pics of what your using them for,..thanks
Quote:
![]() State Trooper: do you know how fast you were going? Me: No not really,..my speedometer only reads up to 140mph and i was going way faster than that
| Bookmarks |
| Thread Tools | |
| Display Modes | |
