5gen EX wheels
Old 03-31-2003, 06:30 PM
Accordacer
Accordacer's Avatar
Default 5gen EX wheels
Wats up guys. Today I got my set of 94 ex wheels. Unfortunatelly I only got the rims and no tires. In a couple days Im planning to get new tires and mount the wheels on my car. My question is what size tires should i get? Whats the widest size tires that I can get? Any suggestions are welcomed.
Old 03-31-2003, 06:33 PM
VRGNCD5
cause it's tight!
VRGNCD5's Avatar
Default Re: 5gen EX wheels
Originally posted by Accordacer
Wats up guys. Today I got my set of 94 ex wheels. Unfortunatelly I only got the rims and no tires. In a couple days Im planning to get new tires and mount them the wheels on my car. My question is what size tires should i get? Whats the widest size tires that I can get? Any suggestions are welcomed.
I have 195/60/15 kumho tires, im sure you could fit 205's on there, I think 215's would be pushing it.
Old 03-31-2003, 08:17 PM
AccordManiac
Korean Member
AccordManiac's Avatar
Old 03-31-2003, 10:04 PM
Import-Tooner
skoooooie!
Import-Tooner's Avatar
try to get as wide as a tire as you can. It will have better traction and will also help prevent damage if you come into contact with a curb. Check out whalentire.com. That is where I got my kumho's. Hella good prices.
Late
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old 03-31-2003, 10:10 PM
dantastic
cx power!
dantastic's Avatar
Location: berkeley, ca --> la, ca representin' tha 510&626
the stock rims are only 5.5" wide... id stick with the oem 195/60-15
Old 04-01-2003, 12:03 AM
BlackChrome
E46/CD5
BlackChrome's Avatar
Doesn't the OE JDM SiR have 205/55/15 on the US 7-spoke EX wheels?
Old 04-01-2003, 03:09 AM
AccordSleeper
Former H22 Accord Owner
AccordSleeper's Avatar
Originally posted by AccordManiac
205/55-15
:werd:
Old 04-01-2003, 08:32 AM
dantastic
cx power!
dantastic's Avatar
Si-R rims look kinda like the 96-97 EX coupe rims, but with exposed lugs instead of covered. they were probably 15x6or6.5 like 4g lude rims
Old 04-01-2003, 08:53 AM
BlackChrome
E46/CD5
'94-'95 SiR Sedan...
http://www02.so-net.ne.jp/~embark/accord.html
Old 04-01-2003, 09:13 AM
AccordSleeper
^those wheels look darker than the USDM ones
anyways i run 205 55 15s and so do many others, they work fine. just make sure that they are approved to fit 5.5 inch wheels. i personally look at tirerack.com and they have these specs for each tire.
some tires that will fit are:
dunlop SP5000s
dunlop FM901s
kumho 712s
