Has anyone used the venom 400 comp
I was wondering if any one has used the venom 400 computer on there 4 cyl accord and if you can really tell a diffrence for $300
thanks
thanks
i've heard bad things about venom computers. all they basically do is trick the throttle into pumping more gas to give the feel that you have more hp and throttle response. you can do the same thing by tightening your throttle cable and that's free.
Summit or jegs
venom 400 is a performance control module that is susposed to increase h.p. by 25% in the 1000-5000 rpm range and plugs in about 30 min. cost around $300
HAN's resident 5-0
Its BS. All it is, like was said above, all it does is make your ECU think your pushing the gas pedal harder. It only does anything at part throttle, it does nothing at WOT.
Re: what about Jet viforce power control module
Originally posted by jeffro84
is it worth the money if not what computer upgrades are worth the money
depends... what year is your accord?
besides.. the chip is always the last mod you want to do. that way you only have to fork out the cash for a dyno tune once.
