stock pad or aftermarket
i got the AEM brake kit and brake pad. and they make noise. is that normal? cause someone told me cause the aftermarket brake pad are different than the stock one. it suppose make noise. is that true?
The deer had to die!
AEM pads usually make noise - not excessive noise. Did you put them in yourself? And if so, did you put the anti-squeal compound on the back of the pad, between the shims?
Re: stock pad or aftermarket
