1990 Accord EX 2 Dr
1990 Accord EX 2 Dr
Ok, i tried to do a search on this, but found nothing. Does anyone know what size are the front speakers in my type of car? I went to crutchfield.com, and they said that it was 5", I hope that's not right. thanks!
Older Honda Fanatic
Crutchfield is correct. They are a 5" speaker... and no, a 5 1/4 will not fit. A 4 will, but leaves a gap, so a plate needs to be fabricated to close the openings.
You can go to a junk yard or www.hondaautomotiveparts.com and get the LX speaker mounts... they accept 6 1/2's.
Edit: Here is a link to honda automotive parts, this shows the speaker brackets used in your car... the top one (#16, 18) is the box/speaker assembly in your EX, #1 is the bracket for an LX, these are what you'd want to be able to put 6 1/2" speakers in the doors.
So you're saying that i can get a LX bracket, and replace the one in my car, so that i can put a 6-1/2" speaker?
Also, in the link that you sent me of the diagram. Is the Illustration #1 the piece that i need to get to allow me to install 6-1/2" speakers up front? Thanks!
Older Honda Fanatic
you are correct... in both questions.
I just suggest this as there are very few 5" speakers out there... a 6 1/2 gives you plenty of options... plus you didnt seem too thrilled that there are only 5's up front.
OK, i ordered those pieces. Now, what all do i need to do to install them. I know that i need to take the door panel off. Do i need to remove the existing 5" bracket? Thanks so much for you help!
Older Honda Fanatic
yup, take the door panel off, and then the 5" speaker enclosure (yes, its actually a small plastic enclosure) is screwed to the door frame with 3 or 4 screws and unplugs... you'll need the wire that runs inside the 5" enclosure for the new speakers. The bracket for the 6 1/2s will mount in the same place as the 5" enclosure.
