1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]
Old 03-07-2010, 09:36 AM
H22FLSol
H22FLSol's Avatar
Default 1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]
What I have for sale is a 1995 Honda Civic Del Sol.
I'm in Ft. Lauderdale (Broward Co.) FL. near Miami
The asking price is $4500
This car has been adult owned and never raced.
This Del Sol has an autocheck score of 50 which is as high as you can get for this car.
It has never been in an accident and passed with flying colors.
I had over $10,000 invested into this car, but now I must let her go as I'm in need of a truck.
Here is your chance to get a great deal.
Here is a break down of everything that the car comes with....
95 Honda Del Sol Body (Good Condition for Year) Org. Paint
Mechanical:
JDM OBD1 H22A swap from Japan Red Top (Purchased June 09 w/ Appx. 40k mi)
Hasport Mounts
Hasport Axles
Custom wiring harness
Stock JDM header modified to bolt up to any del Sol VTEC exhaust system
ACT Clutch (HA3-HDSS)
ACT Prolite Flywheel (600130) 9.9lbs.
Walbro 255 fuel pump
Stainless steel fuel lines
Stainless steel clutch line
GReddy SP2 catback exhaust system
Custom aluminum CAI with K&N filter
Koyo High Flow Radiator
Braking and Handling:
TEIN Control Master TYPE FLEX (DSA006USS1)
GSR front sway bar
ST rear sway bar
ARP front camber kit
shimmed rear camber
1” GSR Brake master cylinder and booster
Wilwood 4 piston 12" Big Brake upgrade up front (slotted/drilled)
matching brembo rear rotors w/axxis pads
Stainless brake lines
Lakewood Titanium Traction bars
15x7 Rays Gram Lights 38mm offset
Interior:
Shifter box mounted under chassis for lowest shifter position
Shift cables mounted through firewall above steering rack for best position
Aux lights wired to be independent of headlights
Headlight buzzer
Complete interior and trunk have been Dynamated
No sound system, but all the wiring is there
Exterior:
One piece Clear Headlights
55 watts Digital H.I.D.’s
Clear Fog Lights
Recently:
Changed all fluids Mobil 1 every 2000 miles
flushed coolant system
brand new Distributor King distributor
Comfort:
Complete A/C system
HCP a/c bracket to mount a d-series a/c compressor
If you have any questions, need more pictures, etc. Please email me @
frankspc23@hotmail.com
as I don't get on here as much as I would like.
Attached Thumbnails 1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-main.jpg   1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-driver-front-top.jpg   1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-front-driver.jpg   1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-eng-3.jpg   1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-eng-1.jpg
1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-eng-h22a.jpg   1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-trans.jpg   1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-interior2.jpg   1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-rims.jpg   1995 Honda Civic Del Sol w/ H22 Motor w/ Extra's delsol [FL]-trunk.jpg
