Jacking up an Integra
Where are the best places to jack up an integra?
I need 3 pieces of information for G3 Teg.
1. Where is the exact point that I can put the jack to lift up the back of my teg?
2. Where is the exact point that I can put the jack to lift up the front of my teg?
3. Where is the exact point that I can put the jack to lift up the sides of my teg?
1. There should be a lip in front of the rear wheel wells. Just look under your car and you'll see it.
2. There should be a lip in behind the front wheel wells. Just look under your car and you'll see it.
3. use 1 and 2 together to lift your car sideways.
You can use the tow hook in the back of the car. There are also those little things on the sides. And also in the front of the car if you look underneath it you will see a little arrow you can jack up the whole front end from that point as well.
