Camber????
Old 03-23-2003, 08:11 PM
whiteinte95
whiteinte95's Avatar
Default Camber????
I put on rear camber kit and now the fender somehow scrapes (literally digs in...) the sidewall of my rear tires. Does this happen often???
Old 03-23-2003, 08:16 PM
fizzbob7
90 accord h22a
fizzbob7's Avatar
if you have tires that are too wide or wheels with the wrong offset....the top was tucked in more since you had negative camber, and now since it's closer to 0 degrees, it's scraping....you can either adjust it back toward the negative side until it clears and just deal with the inside tire wear, or get a new tire/wheel combo
Old 03-23-2003, 09:45 PM
GSRacer93
He's so hot rite now
GSRacer93's Avatar
roll the fenders
Old 03-24-2003, 06:09 AM
teg_fan
I like integra's
teg_fan's Avatar
Originally posted by GSRacer93
roll the fenders
Yes, roll the fenders. Get a wooden bat and use at as a lever pivoting on the edge of your tire, and bend back that lip. You might want to take off that rubber lining on that ledge before you roll it back though, you'll find a lot of dirt stuck under it.
Old 03-24-2003, 07:55 AM
whiteinte95
How hard is it too roll the lip? Will it most likely solve my problem? thanks.
