97-99 CL and 96-98 TL front brake/knuckle/hub info needed!
Ok... so from what I have gathered, the 97 3.0 CL had a 4x114.3 hub over rotor setup like the 2.2/2.3 CL's, while the 98-99 3.0CL's had a 4x114.3 rotor over hub setup. Am I correct?
If so, are the knuckles between the CL's that used the rotor over hub and the hub over rotor designs the same???
and if so again, has anyone swapped the rotor over hub system onto their hub over rotor CL?
Now Anyone know if the 3.2 TLs knuckles (96-98) are swapable onto the 95-98 2.5 TL's (which had 4x114.3 and hub over rotors) control arms?
and lastly, anyone know if the 2.5 TL and 2.2/2.3 CL knuckles are the same or interchangeable?
