Cheap Way to Increase Airflow and Make the Car Louder
Old 03-18-2003, 08:20 AM
AcuraFanatic
AcuraFanatic's Avatar
Default Cheap Way to Increase Airflow and Make the Car Louder
Cleaning under the hood of the car yesterday and decided to tinker with the air intake system. I pulled the four clips that attach the upper part of the box off.
I then lifted the cover, and lifted the filter up to it was against the top of the box. I took the clips and pulled them up so they supported the filter (the black edge around it) and the top of the box.
The filter is now up about an inch all the way around, along with the top of the filter box, so it still gets perfect air filtration while allowing increased airflow. It makes it sound significantly deeper at around 3000RPM-4000RPM, and then fairly noticeable elsewhere, especially at WOT. Sounds just like a CAI.
It took me two minutes to do. The car sounds great now, and didn't cost me a penny. If my words are hard to understand, I'll try to get some sort of diagram up shortly.
You end up by-passing the resonator for the most part now as well, for less air is drawn from the bottom of the car. The only downside is you're pulling in hotter air (closer to the engine), but I figure the increased amount of air should somewhat offset the losses.
:thumbup:
Old 03-18-2003, 08:23 AM
AadosX
AadosX's Avatar
cool
Old 03-18-2003, 08:28 AM
dantastic
cx power!
dantastic's Avatar
Location: berkeley, ca --> la, ca representin' tha 510&626
why not just pull out the resonator? the original cai :exnbp:
Old 03-18-2003, 08:29 AM
AcuraFanatic
Involves a lot more work than what I did. Also, with the resonator you're still pulling in the same amount of air, it's just louder. You can also restore it to "stock" in less than 30-seconds the way I did it.
Old 03-18-2003, 08:30 AM
AcuraFanatic
Besides, why not? :exnbp:
Old 03-18-2003, 08:32 AM
dantastic
cx power!
dantastic's Avatar
the resonator isnt hard to take out, and ur pulling cold air out from behind the bumper
Old 03-18-2003, 09:20 AM
H-Accord-22
Duh
H-Accord-22's Avatar
ah..........u sure that u'll still get the same filtration?
Old 03-18-2003, 09:39 AM
jsinger
IH8S810
jsinger's Avatar
Yeah that's what I did... took like... 20 min. Air box and Air resonator. Took both all the way out, I keep the filter on with... lol fishing wire... it does sound really good and deep like AF said.
Old 03-18-2003, 10:31 AM
99accord
www.poksquid.com
99accord's Avatar
spend some money you cheap bast.... oh... sorry.....
you can get a short ram for any car for about $30.00.....
Old 03-18-2003, 10:50 AM
dantastic
cx power!
dantastic's Avatar
yea, but ur filter will get dirtier quicker. u dont need to take off the bottom half of the air box (just under the filter). just leave it there.
