1999 acura 3.2
Old 01-25-2010, 04:21 AM
ca
ca's Avatar
Default 1999 acura 3.2
Hi, The heater on my acura only blows cold air, i'm pretty sure I have to replace motor for the heater box, but need some help, step by step kind.thanks... ca
Old 01-26-2010, 05:19 PM
Carbuff
Carbuff's Avatar
I haven't done that yet. You go first!
I have found that turning the temp control all the way up (90 degrees F) for a minute will move the door and the heat will return.
Old 03-21-2010, 05:31 AM
JamesTL32
JamesTL32's Avatar
I've had to do that same thing with my heat since day one (Jan. 00) with my 00 TL3.2.
Be nice if someone would post a real fix for this (other than turning the temp all the way up).
Old 03-21-2010, 10:30 AM
Carbuff
Carbuff's Avatar
The problem is with the hot air mixture control motor under the dash. They are expensive.
You replace yours first, tell us how much it costs for the repair.
