Would the RSX HU fit in an Integra?
X-Moder8er
I believe the stock RSX has a din sized deck, so it would fit. I'm not certain about if the plugs are the same though.
The RSX-S deck would definitely NOT fit because of its shape.
As the ACCORD TURNS!
Mike
Older Honda Fanatic
Originally posted by MikesCommuter
PLUS I think the Type-S has the BOSE system if I am not mistaken
Mike
Mike
The Base RSX deck will fit... but the wirring is different, and also keep in mind that it does NOT have a remote turn on output, for a power antenna or amps. A plug for the back of the radio can be found here.
Originally posted by SumAccordGuy94
Correct!
Correct!
thanks for the info. I guess afterall I can't use it since I have a power antenna.
