Go Back   Honda-Acura.net > Auto Forums > '92+ Civic/EL & Del Sol
Thread Tools Display Modes
Old 09-06-09, 05:00 PM   #1
Shameinator
Swollen Radiator Hose
My upper radiator hose is swollen and buldging. I am going to replace it. My question is do I need to worry about my water pump being on its way out? the reason I ask is because if I remember correctly this can be a sign.
I searched the forum but couldn't find much. Any help would be great.
The coolant is only about 8k old and the thermostat is new and I have no overheating problems whatsoever. the motor has 95K on it.
I know I will need to do the waterpump timing belt and timing belt tensioner soon but I am trying to avoid it for a few weeks so i can get the money up to do the work.
      Registered and logged-in users don't see this ad!
Register your free account today.
Shameinator is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-07-09, 01:32 AM   #2
bluetwo
Relevance is irrelevant
bluetwo's Avatar
Send a message via Yahoo to bluetwo
Since it's really only safe to say you need the pump and timing belt done I want to say do it to be on the safe side.
Still seems like you might be able to make it a little longer but why push it?
________________________
00 Honda Civic EX daily driver
84 Honda Nighthawk CB700
bluetwo is offline   Reply With Quote
Old 09-07-09, 01:47 AM   #3
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
That is a sign of a blown head gasket. At least that's what happened with my 93 Civic. I replaced the hoses and they started to balloon again, took it to the shop and verified that it was.
Autocross Help Page
CivicSiRacer is offline   Reply With Quote
Old 09-07-09, 08:59 AM   #4
asiandoood
in search of unicorn(s)
asiandoood's Avatar
Send a message via AIM to asiandoood
You'll need to replace the hoses as soon as possible before they burst. Radiator hoses decay from inside out. I would suggest not driving long distances until the hoses are replaced as you may risk blowout and overheating and /or more damage from it.
Do the water pump when you do the timing belt. Honda's are usually due at about every 80-90k miles. If your water pump is on the way out, it would mean bigger problems such as overheating, not ballooning hoses.
[BLOG] [N1 Concepts] [ENDLESS 8]
asiandoood is offline   Reply With Quote
Old 09-07-09, 03:15 PM   #5
Shameinator
thanks for all the input guys. I am planning ondoing the water pump and timing belt in the next couple of weeks I just need to get the money first. I have side work going on that i haven't gotten paid for yet. I am almost positive I dont have a blown head gasket but these are the same hoses from my old motor when i did so they probably just need to be replaced. I will go buy some hoses and coolant today and fix the immediate problem.
Old 09-09-09, 12:33 PM   #6
IanB
MB4
IanB's Avatar
Quote:
What is the logic behind this? What would cause a rad hose to balloon from a blown head gasket? This seems like more of a coincidence than a correlation.
'99 Acura 1.6EL Premium 5M VSM "Project 2.0EL"
'05 Subaru Legacy 2.5i limited wagon
IanB is offline   Reply With Quote
Old 09-09-09, 04:01 PM   #7
CivicSiRacer
Quote:
Well considering I changed my head gasket 4 months ago and my hoses are not ballooing anymore. I took it to my sponsor who works on race cars all he had to do was look in the radiator and you can see little bubbles coming up. These were bubbles from the cylinder pressure.
The pressure inside your coolant system is only about 15psi or so. The pressure coming out of the cylinder heads is usually 190-210psi ish. So pressure from the cylinder heads was leaking into my coolant causing the hoses to balloon. Yes you could have a bad head gasket into the exhaust system causing you to billow white smoke, I wasn't getting that.
Plus the hoses you should be able to touch with your bare hands. My hoses were freaking scalding. Heat coming from the cylinder heads.
Autocross Help Page
Old 09-09-09, 07:37 PM   #8
IanB
MB4
IanB's Avatar
Thanks for the additional info. I've never heard of that before.
Old 09-12-09, 01:41 AM   #9
CivicSiRacer
Yeah I never had a blown head gasket before. I always thought a blown head gasket would mean white smoke coming out the tailpipe.
During autocrosses my coolant temperature gauge would show perfect temps. 1st run still fine, every run after that the needle would rocket to red zone. So there was heat coming from somewhere.
And the other thing that just went on me (July 2009) was my radiator (from the pressure fromthe cylinders) which I changed when I got the car (back in 2006) when the same shop found a crack in the radiator cap neck. So I'm guessing the previous owner knew about the head gasket, which over pressurized the cooling system, which cracked the radiator, which lead to the ballooning hoses.
I swear my car is possessed.
Autocross Help Page
Old 09-12-09, 12:06 PM   #10
cruzalekz
you just need a new radiator cap
cruzalekz is offline   Reply With Quote
Old 09-12-09, 10:14 PM   #11
Shameinator
yea I replaced the hose and the cap is next cause I need to go get coolant I leaked a little out while replacing the hose.
Old 09-13-09, 05:30 AM   #12
Shameinator
I replaced the leaked out coolant and I did a simple head gasket check. I had my brother start the car while I watched the fluid in the radiator for bubbles. I had no bubbles and I let it run to make sure it did not bubble. I let it go through one heat cycle and checked the fluid again. No bubbles and no loss of fluid so i think its safe to say my hose swelled due to being old and being on there when my last motor with a bad head gasket was in there.
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
