Go Back   Honda-Acura.net > Tech Forums > Engine Swaps, Tech & Tuning
Thread Tools Display Modes
Old 08-29-09, 07:08 PM   #1
krongnome24
Send a message via AIM to krongnome24
Turbine wheel to housing issue!
I have a T3 turbine housing 20358-72 with 0.63 a/r housing. The original Turbine wheel in this turbo has a small wheel, too small for the housing its in. The housing has about a 2" exducer and a 2 3/8" inducer.
The issue is that the current "standard" T3 turbine wheel for this housing is exducer: 1.802" 45.77mm and inducer: 2.324" 59.06mm.
So there is a large amount of room between the wheel and the side.
Question 1: how much room should be between the wheel and the housing.
Question 2: Looking at a T04B standard wheel (# 451311-0014) it seems to have a much closer fit with exd: 1.914" and ind: 2.322". This would leave about one millimeter on each side of the wheel. Would this be too close?
Question 3: which turbine wheel is the correct one for this housing?
I have been looking online for days trying to find the correct wheel.
Thank you very much for your time.
      Registered and logged-in users don't see this ad!
Register your free account today.
krongnome24 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-30-09, 01:09 AM   #2
krongnome24
I found out the information I needed. Turns out because the Garrett number is 430225-0013 for the "standard 0.63 a/r 20358-72" I have a turbine housing from a TB0322.
So turbine wheels 409646-0052, 409989-0072, 451311-0003 and 451311-0014 will all fit in The t3 turbine housing (430225-0013). And any of these will fit in the housing with only minor differences.
some of the turbos that came with this T3 0.63 a/r housing are
TW4B
TW4C
TO4B
So After I get the part needed I will have a T3 housing from a TB0322 0.63 a/r
and the T72 old style P trim compressor wheel with a .58 A/R housing. Which seems like I found the information I needed but wanted to make sure its available here as well.
Old 10-02-09, 11:21 PM   #3
smurphdiggity
what is your combo?
smurphdiggity is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
