08-28-09, 03:00 PM
I got worms.
2010 Acura RL - Specifications
- Aug 28 — POWERTRAIN Engine Type 3.7-liter, SOHC, 60-degree VTEC® V-6 Horsepower 300 hp@ 6,300 rpm Torque 271 lb-ft @ 5,000 rpm Redline 6,800 rpm Bore and Stroke 3.54 in x 3.78 in (90 mm x 96 mm) Displacement 223.6 cu in (3664 cc) Compression Ratio 11.2:1 Induction System Programmed Fuel Injection (PGM-FI) with multi-hole fuel injectors Valvetrain Variable Valve Timing and Lift Electronic Control (VTEC?) for intake and exhaust valves, 4 valves per cylinder, with a belt-driven single overhead camshaft Engine Block Cast aluminum alloy, aluminum alloy cylinder liners Cylinder Head Cast aluminum alloy, 4-valves-per-cylinder Emission Control Close-coupled catalytic converter system with after-cat EGR;
EPA TIER 2 ? BIN 5 and CARB LEV II ULEV certification Ignition System Direct ignition system with knock control Alternator 130 amp max Battery 12V, maintenance free Recommended Fuel Premium Unleaded Drivetrain Layout Transversely-mounted front engine, Super Handling All-Wheel Drive? Transmission Sequential SportShift 5-speed automatic with Grade Logic Control and Shift Hold
Gear Ratios (:1) First
Second
Third
Fourth
Fifth
Reverse
Final
Final Drive 2.697
1.606
1.071
0.694
0.491
1.888
1.238
4.533 CHASSIS Body Type Steel and aluminum unit body Front Suspension Independent double-wishbone with coil springs and stabilizer bar Rear Suspension Independent multi-link with coil springs and stabilizer bar Shock Absorbers Gas-pressurized dampers with Progressive Valve technology Stabilizer Bars Front 1.18 in. (30 mm) diameter hollow, 0.25 in. (6.5 mm) wall thickness Rear 0.75 in. (19 mm) diameter solid Shock tower bar 1.26 in x 0.87 in (32 mm x 22mm) diameter;
0.09 inch (2.3 mm) wall thickness Steering Type Electronically controlled, speed sensing, variable power-assisted,
rack-and-pinion steering Steering Ratio 16.1:1 Steering Wheel Turns (lock-to-lock) 3.0 Turning Circle (curb-to-curb) 39.7 ft (12.1 m) Wheels 18x8-inch, 7-spoke cast aluminum alloy Tires Michelin Pilot HX MXM4 P245/45R18 96V M+S Braking System Power-assisted, 4-wheel disc brakes with ABS and Brake Assist Front disc brakes 12.6-in (320 mm) diameter ventilated rotors with 4-piston calipers Rear discs brakes 12.2-in (310 mm) diameter ventilated rotors with 1-piston calipers Vehicle Stability Assist? (VSA®) Throttle control and 3-channel brake control (utilizing yaw, lateral g, speed and steering sensors) CAPACITIES Crankcase 5.3 US qt (5.0 L) Cooling System 9.1 US qt (8.6 L) Fuel Tank 19.3 US gallons (73.3 L) Volumes Passenger
Cargo
Total 99.1 cu ft (55.3 front, 43.8 rear)
13.1 cu ft
112.2 cu ft FUEL ECONOMY City/Highway/Combined 16/22/18* *Based on 2010 EPA mileage estimates that reflects new EPA fuel economy methods beginning with 2008 models. Use for comparison purposes only. Do not compare to models before 2008. Your actual mileage will vary depending on how you drive and maintain your vehicle. EXTERIOR DIMENSIONS Wheelbase 110.2 in (2800 mm) Track, front 62.0 in (1576 mm) Track, rear 62.4 in (1585 mm) Overall Length 195.7 in (4973 mm) Overall Width 72.7 in (1847 mm) Overall Height (unladen) 57.2 in (1455 mm) Minimum Ground Clearance
(non-load) 5.7 in (145 mm) WEIGHTS RL
RL with Technology Package
RL with Tech Package and CMBS? 4,083 lbs
4,085 lbs
4,110 lbs Weight Distribution (% front/rear) 58/42 INTERIOR DIMENSIONS Front Head Room 38.4 in (977 mm) Leg Room 42.3 in (1076 mm) Hip Room 55.1 in (1400 mm) Shoulder Room 58.5 in (1487 mm) Rear Head Room 37.2 in (948 mm) Leg Room 36.3 in (923mm) Hip Room 54.0 in (1372mm) Shoulder Room 56.1in (1426 mm) WARRANTY Vehicle 4-year / 50,000-mile limited warranty Powertrain 6-year / 70,000-mile limited warranty Outer Body Rust-Through 5-year / unlimited-mile limited warranty Acura Total Luxury Care (TLC) with roadside assistance 4-year / 50,000-mile
More...
