| The Basement Non-Honda/Acura discussion. Content should be tasteful and "primetime" safe. |
Thread Tools | Display Modes |
#1 | |||||||
fishing peeps: fishing line question
2006 Acura TL 2000 Audi S4 Last edited by flyromeo3; 08-13-09 at 05:30 PM. |
| Sponsored Links | ||
#2 |
I go duffy on dem bitches
i bought some red string, it's like spiderwire but i have no clue what it's called. iirc it was 50lb and must've been 12lb size. not sure what kind of reels you're using but if it's baitcaster keep in mind if you birdnest one of those it's pretty unpossible to fix without cutting.
eta: i've seen it in walmart, kmart, etc so i'm sure any place that sells sporting goods should have it but yes, i'm certain dick's would.
www.BayouShooter.com - Louisiana Firearm Discussion "From each according to his ability, to each according to his need." - Karl Marx |
#3 |
un-Touch'd krew
Deep sea I would go with a minimum of 30lb braided line and a solid baitcasting reel. From there set your drag to half the lines rated capacity and you should be good as long as you let the fish run itself out, you try bringing him straight in and it will snap easily.
#4 |
i ended up picking up 30lb test PENN line. Normally 20lb test is .45mm in diameter. This 30lb is .44mm. So this seemed to be close to what i wanted.
Thanks
2006 Acura TL 2000 Audi S4 |
#5 | |
un-Touch'd krew
Quote:
I would go braided, it works better in the long run.
www.dinofuelalternatives.com Contact me for all your brick needs...I have a brick for just such an occasion. "When governments fear people, there is liberty. When the people fear the government, there is tyranny." -Thomas Jefferson- "I'll keep my money, guns and freedom. You can keep the "Change." |
#6 |
cali whore
For baitcasters I load up with spectra then top it off with about 150 yards of monofilament (spectra being about twice the strength of mono... ex: 40lb spectra/20lb mono). Spectra will last for years as long as its packed down tight. Then all you have to do is change out the topshot every few trips. Saves time and money. Albright knot for the spectra to mono connection.
As for brands... for spectra I use spiderwire for under 40lbs, Izorline for anything heavier. For mono I like Pline, Maxima, or if Im lazy Ill go to Big 5 and get Trilene Big Game or Ande. As long as the line hasnt been sitting on the shelves for months.
cartel roach ltd | viper v5 |
#7 |
un-Touch'd krew
Hmmm never mixed like that Len, might have to give it a try next time I head out to the ocean.
#8 |
BOOM goes the dynamite!
we're going fishing tomorrow morning at a local lake (santa ana river lake for you socalers). i got a couple of poles and a tackle box from my father-in-law, but i have a feeling i'm gonna have to replace a lot of stuff because it's all old.
#9 |
un-Touch'd krew
Old isn't bad in fact once you clean it up a bit it works better than some of the newer stuff.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
