General 4WD RWD n FWD questions
Hi all the experiance racer here :wavey:
just wondering why issit only 4WD n RWD cars can drift n why not FWD hondas Civic n Integra ? ? ? I just want to know whats happening on the clutch break n accelerator during a drift ? ? ? why issit when a RWD car is drifting, the driver will be controlling the accelerator and when driver want the car to go straight again after the drift, he will also press the accelerator ? ? ? both drifting n going straight again are control using accelerator ? ? ? that must be very difficult ? ? ? ? ?
ThaNkzZzZ:naughty:
ThaNkzZzZ:naughty:
Re: General 4WD RWD n FWD questions
Originally posted by VtecApprentice just wondering why issit only 4WD n RWD cars can drift n why not FWD hondas Civic n Integra ? ? ? I just want to know whats happening on the clutch break n accelerator during a drift ? ? ?
Kick in the clutch on your FWD car during a turn and you'll plow off the road. Kick in the clutch on a RWD car during a turn and you'll be facing the apex.
Originally posted by VtecApprentice why issit when a RWD car is drifting, the driver will be controlling the accelerator and when driver want the car to go straight again after the drift, he will also press the accelerator ? ? ? both drifting n going straight again are control using accelerator ? ? ? that must be very difficult ? ? ? ? ?
For RWD, you have to modulate the throttle with a bit more care to avoid power-on-oversteer.
Shingo
ps. Do you watch Initial D?
Honorary Moderator Alumni
In my personal opinion drifting is the slowest way around a corner where grip is high. Drifting will make you quicker if the surface is loose or low on grip.
But to drift the rear wheels should be pushing the car, and the front wheels should be turning. Can't really do that in a FWD car - this is considered skidding or oversteer.
Time and time again I've seen guys at autocrosses ask why when they were drifting their times were slower than mine. My only response is if you are slipping (drifting) then you are not accelerating - which means quicker times. I like to be on the accelerator 95% of the time and braking 5% of the time
Autocross Help Page
Autocross Help Page
