Go Back   Honda-Acura.net > Auto Forums > CRX & Pre '92 Civic
Thread Tools Display Modes
Old 04-13-09, 10:37 PM   #1
jmunoz_671
No spark condition....need advice....
I just brought a 89 honda civic hb si, has it original 1.6l engine, i have replaced that ignition coil and ignition module, still no spark. Returned parts. Replaced the whole distributor with a reman from napa auto parts, same condition, no spark. Trace wiring, cleaned harnesses, inspect ecu, now this car has a pr4 ecu, is this ecu compatiable with a pm6 ecu, is it possible that the ecu is out, if so how do i test to see if it works or not..............
      Registered and logged-in users don't see this ad!
Register your free account today.
jmunoz_671 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-14-09, 08:16 PM   #2
941crx
junkyard junkie
941crx's Avatar
Are you sure it's no spark? I thought I had that problem one time and turned out to be the fuel module thing under the dash on the driver side that was faulty after I went through all the above steps you mentioned.. I can't remember how to test them I'll look through my printouts I'm sure it can be found online if I can't find my copies.
Just a thought dunno.
One other thing..I also had iffy starts till I replaced those stock wires even if it's just oem replacement those older wires are crap after a while IMO but if it's no spark from the get go before wires..
hhr = gayer than having "anal" in your sn-scotttharobot
941crx is offline   Reply With Quote
Old 04-14-09, 11:24 PM   #3
jmunoz_671
i test for spark after the wires, out of the distributor, and directly from the ignition coil. no spark at all. i'm pretty sure its not a fuel problem, after cranking i can smell fuel out the tail pipe. trying to find a PM6 ECU but its not easy to find. might be looking in all the wrong places.
Old 04-15-09, 02:57 AM   #4
941crx
junkyard junkie
941crx's Avatar
If I remember right, the pr4 was used in an integra with a bseries (http://hondaswap.com/reference-mater...cu-list-29129/) so I'd say that would be a problem.. yeah pm6 is a pain to find.. I ended up going zc and wanted to do pm6 or pg7 and went for the pg7 based on the performance side.. I know the guy has another one if a pg7 would work.
Don't ya love those weird hour replies? I do.. then again I've spent the last few hours looking for a valve spring retainer... damn baggy had a hole in it..
Hope that helps some and if a pg7 would work I can hook ya up with someone that has it and I vouch for him.
Last edited by 941crx; 04-15-09 at 03:00 AM. Reason: I effed up the word valve and had vlave
Old 04-15-09, 06:04 PM   #5
jmunoz_671
What car does a pg7 come from?????? What is the different between and pm6 and a pg7 ecu????? Pretty new to the imports.... Don't know much about what is compatiable parts..... Any info is helpful....thanks
Old 04-15-09, 11:52 PM   #6
941crx
junkyard junkie
941crx's Avatar
Well in my case I"m using a pg7 which is from an integra, the pm6 is from the si, both work for the engine I'm using which is the zc. I'm not sure if a pg7 can work for a regular crx si engine I'll check around but I'm sure there are more knowledgeable people on this then I am, I switched over from gas hog domestics nothin newer then 91 so I'm still getting used to ecu swapping.
My question is, why would a bseries ecu be put in a si that has the stock si dseries engine.
Old 04-16-09, 08:23 AM   #7
KrazyAboutHondas
all motor or nothing
KrazyAboutHondas's Avatar
change the whole distributor, the igniter might be bad
too low for fat chicks
KrazyAboutHondas is offline   Reply With Quote
Old 04-17-09, 11:00 PM   #8
jmunoz_671
I had my buddy test the pr4 ecu in his 89 crx with the stock d16a6, started right up. Traced the wire harness once more, and found a ground connection coming from the wiring harness corroded, clean connection, car fired right up........ Thanks for the help.
Old 04-18-09, 01:36 PM   #9
cruzalekz
check main relay
cruzalekz is offline   Reply With Quote
Old 04-30-09, 06:15 PM   #10
compfreak2002
You wouldnt be getting fuel if the main relay is bad
To check for spark
Clean your battery terminals and ground cables to the motor and transmission,
then recheck connections to distributor with multi meter and service manual, then replace the entire distributor and I would get the right ecu, what the hell is that integra ecu doing in your civic without a swap anyway?
compfreak2002 is offline   Reply With Quote
Old 05-02-09, 06:15 PM   #11
cruzalekz
check timing belt
Old 05-11-09, 02:45 AM   #12
crx+rx7owner
crx+rx7owner's Avatar
i think its kinda starnge that no one has stated the obvious here. i think it is far more likely that, if the car ran before, and you've repalced all of the part you have, it is likely that the harness became damaged. i would check the resistance across all of the wires to the distributor from the ECU. if its not the the ECU itself, then it would have to be the harness its the only other part of the system. check the wires and fuses before you throw parts at an electrical issue. you'll save alot of money.
crx+rx7owner is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
