Misc. Honda/Acura: Check CV Boots
Old 01-17-2003, 05:13 PM
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
Default Misc. Honda/Acura: Check CV Boots
Import Street Scenes - News, photos, videos and info .. straight from the streets!
http://www.importstreetscenes.com
Thanks www.accordracing.com for the DIY
1) Lie on your back and slide under the front of the car as far as you can.
2) Using a flashlight or drop light, locate the drive axles: They are
metal shafts that connect to the back of each wheel from the transmission.
3) Visually inspect the rubber boots at each end of both drive axles. You will be inspecting a total of four boots.
4) Look for signs of wear and tear such as rips or cracking.
Feel each boot for indication of leakage - the boots hold thick grease that lubricates the CV joints.
5) Call your mechanic and make an appointment to replace any leaking or torn CV boots. A leaking boot can quickly lose all of the grease and damage your CV Joints.
ps: A torn or ripped CV boot can destroy the CV joint in a matter of days, especially if the weather is wet. Putting off this repair will cost you more in the long run. It is a waste of money to replace the CV boot if the CV joint is already damaged.
Old 01-20-2003, 11:38 AM
AccordCoup94
AccordCoup94's Avatar
my cv boots were torn on my 94 accord for well over a year and i did not have any probles driving. honda made some really good axels. the only annoying thing about it was the loud clicking sound everytime i turned.
Old 01-20-2003, 03:38 PM
REbornHONDAneer
Honda Biased
REbornHONDAneer's Avatar
i assume they were damaged after you did finally get them replaced?
Dave
Old 02-09-2003, 12:16 PM
91redsi
91redsi's Avatar
what happens if u never replace them?
Old 02-09-2003, 01:14 PM
98CoupeV6
98CoupeV6's Avatar
If they're not worn, nothing.
Old 02-21-2003, 03:31 PM
Jokieman31
Jokieman31's Avatar
Default Loud clicking
That's funny man, that loud clicking you were hearing were the axles slipping. hehehe.
The axles were slipping because you got dirt and grime up in there and it rounded off the ends of your cv's. hehe.
On a side note: Unless the car is near new, have the cv joints replaced anyway. Labor wise- they have to take the cv's completely apart, and it's not cheap, so might as well buy the parts and have them replace those too.
That is, unless the car is less than 5 years old.
Old 02-21-2003, 07:27 PM
TypeSH
TypeSH's Avatar
can an axle go bad even if the boots are not ripped and not leaking? I have a clicking/ticking noise on the driver front side, dont know if its from the strut/spring or axle...
Old 02-22-2003, 02:41 PM
white_n_slow
it's my D in a B
white_n_slow's Avatar
my friend's '89 civic si has had bad CV joints for almost 3 years now. It clicks and grinds around the corners, but still drives. I think they stop working properly, but never actually die.... thats my theory anyway. His car has nearly 300k miles on it. :exnbp:
Old 04-03-2003, 04:26 PM
gpasumam
gpasumam's Avatar
So, how much does the replacement of the cv boots cost, at a dealer?
Old 04-04-2003, 06:46 AM
rutgers19
rutgers19's Avatar
yeah, how much would repalcing both axles and/or boots cost? mine on my civic have been torn for about 8 months and i've had no problem with them at all, even with heavy snow and rain...?
