Misc. Honda/Acura: Custom Clear Corners
Old 01-17-2003, 04:34 PM
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
Default Misc. Honda/Acura: Custom Clear Corners
Import Street Scenes - News, photos, videos and info .. straight from the streets!
http://www.importstreetscenes.com
Thanks www.accordracing.com for the DIY
Difficulty: 3/5
Tools/Supplies
- 2 Stock corners
- Philips screw driver
- Flat paint
- Access to an oven
1. Remove stock corners
2. Place in preheated (350) oven on piece of foil on baking sheet for 3-5 mins. Another option is to use a heat gun and carefully work your way around until the factory silicon is pliable.
3. Carefully pry the outside lens off
4. On the back of corner there is a black rubber tube/condom type thing, rip that off
5. you'll find a screw, unscrew this to remove the inside lens that is holding the orange reflector andCarefully push/force out the reflector, it is very lightly glued in but the plastic will crack if you're not careful
6. Screw the second lens back on w/o the reflector
7. Use silicon to glue the outside lens back and your done
8. To make black housing corners, flat or semi-gloss black paint works best.
9. Go ahead and buy high temp if you want to do your headlights as well.
10. And use black silicone to put the housing back together instead of clear.
