1994 acura vigor factory car alarm
my 94 acura vigor factory car alarm wont shut off and i cant start up car is there anyway that i can disarm alarm
Alarm Disarm
Is there a fuse for it? Do you have the manual for the vehicle? If you disconnect the negative (black) battery cable for 20 minutes that should clear out the car's computer (make sure you have the radio code handy for restart if it's the factory radio)...just a few thoughts
I just put the key back in. hmmm, doesn't happen to me unless, i went in from the other than driver side.. I'm getting a whole new upgraded alarm, so I'm not trippin on that.
Problem with the Vigor's factory alarm is that the electronic door lock actuator loses contact with the switch over time due to corrosion and will not send the signal to the alarm unit. The car will think that the door was not unlocked with the key, and will trigger the alarm to go off.
To remedy this, you can open the door from the passenger side like someone already mentioned, or fix the lock actuator. There's some great write-ups for this problem over at the Yahoo Groups site. You can find them over at acuravigorclub.com and read through some of the Timely Topics Articles, written by members of the Yahoo Group.
Hope that helps.
Shawn
Hope that helps.
Shawn
wrong place
I just bought a 96 A when i push the alarm key it keeps unlocking and it will do that for a few sec does any1 know wat is wrong with it its the factory alarm
