98 2.0L ITR $19k (Nevada)
Old 02-03-2009, 06:25 AM
TAG
TAG's Avatar
Default 98 2.0L ITR $19k (Nevada)
I am offering for sale a 1998 Acura Integra Type R that has been extensively modified. Very high quality parts have been used throughout the car in the areas that have been upgraded. The car has a fully built 2.0L racing engine (designed for road course use), modified suspension, and brakes (the seats and other safety equipment were installed to SCCA specifications). The engine, and all modifications to this car were done by LDL Speed Shop in Las Vegas, Nevada.
With some custom fabrication, we also were able to retain the air conditioning, despite the big tube DTR-FAB (Sigma-Six Racing) header. Every effort was taken to retain a clean “finished” look for the interior, even though it has been completely redone. The front and rear seats and rear seat brackets were removed, along with the ITR center console. The door panels were also customized by an auto interior shop to allow for the size of the racing seat upper bolsters.
Sparco EVO XL racing seats, Sparco/Schroth 5 point harnesses, a padded Autopower roll bar, new custom fit rear carpeting, and a JDM ITR e-brake center console replacement were installed. I have included pictures of the interior from different angles. The Stereo/CD player, power windows, heater, A/C, keyless entry, and alarm all work perfectly. Unfortunately the car is too loud to listen to the stereo though, due to the Burns Stainless TIG welded custom 3” exhaust. Lol!
The LDL built racing engine has less than 2,500 miles on a complete rebuild, and the chassis has 65,000 miles. The exterior of the car looks as if it were new. I have $25k+ invested in this car, over and above the original cost of the car. Receipts can be provided to the new owner.
The WORK RSZ-R 15”x 7”+43 offset rims are mint, except the stickers have been removed, and the Nitto NT-01s are almost new. Here is a component list, with accompanying photos:
1998 2.0L ITR
ENGINE/TRANSAXLE
Brand new B18C5 short block (minus rods and pistons) sleeved to 2.0L+ (85.5mm x 87.2mm) by RS Machine
Entire rotating assembly balanced. (fuel cut: 9200rpm) The engine was also built to run on 91/100 octane, or E85.
ARP engine stud kit; ARP head stud kit
Arias custom forged pistons; 11.5:1 (coated piston tops and skirts)
Ferrea polished stainless steel competition valves
Crower rods
JUN III cams and valve springs
Toda Cam gears
Supertech Ti retainers
Walbro 255lph fuel pump
AEM FPR
B&M FP Gauge
RC 440cc injectors
RPM Service 72-70mm throttle body
DTR-FAB custom stainless 4-2-1 header w/ HPC thermal barrier coating
Mugen baffled oil pan
HPC oil-shedding coating inside the valve cover
Accusump 2 Qt. oil accumulator (not currently connected)
JAZ vented catch cans w/ drain valves (two)
FAL racing fans (custom fabrication to retain A/C)
Koyo aluminum racing radiator
Samco silicone hoses
Mugen cooling system package
Toda high-power clutch/light-weight flywheel
JDM ITR 4.7 final drive
Extrude Hone, port matched, flow benched ITR intake manifold
Hondata S300 engine mgt., thermal barrier intake manifold gasket
Viton valve guide seals
Comptech Icebox intake
Vi-Tek racing ignition wires
Work done by LDL and others:
port/polish; open up combustion chamber to match 85.5 mm bore; deshroud valve pockets; flow bench; 3 angle valve job; bronze guides; balance crankshaft and micro-polish journals; balance entire rotating assy.
LDL Custom Burns Stainless TIG welded 3" exhaust w/ 3” stainless Thermal Research muffler
Energy Suspension motor mount inserts and shift linkage bushings.
Spoon Magnetic drain bolt set
SUSPENSION
Mugen Lowdown Sport Suspension (5-way adjustable)
Mugen rear 26mm sway bar
Skunk2 Racing adjustable front upper control arms (new style)
SPC rear camber adjustment kits
Spoon Sports front and rear upper tower bars
BRAKES
Goodridge stainless steel brake lines
Axxis Ultimate racing brake pads
Brembo high performance rotors
WHEELS/TIRES
WORK RSZ-R Competition 15X7, 114.3, +43 offset
205/50-15 Nitto NT01 Tires.
ARP extended length wheel studs
INTERIOR
MOMO alloy pedals
Autopower 4-point bolt-in roll bar
Sparco/Schroth 5-point harnesses
Rear seats and seat brackets removed
Custom rear carpeting
Extras:
There are also two Acura OEM Integra Type R nose masks in perfect condition that come with the car, and also a cut and polished valve cover w/ HPC oil shedding coating. This car has to be seen to be appreciated; the paint has had a color sand and polish, and it gets routine applications of Zymol. The paint is as smooth as glass. This is a California/Nevada owned car since it was new, and has absolutely no rust. The car originally produced 234whp on the Mustang Sport Compact Dyno at LDL Speed Shop.
Price lowered to: $17,000
1.
2.
3.
4.
5.
6.
Thanks for looking...
Old 02-06-2009, 05:18 PM
TAG
TAG's Avatar
Price lowered to $18,000
Old 05-28-2009, 12:08 PM
TAG
TAG's Avatar
Price lowered to $17,000...
Old 06-03-2009, 10:03 AM
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
it's purdy! Bump for ya.
Autocross Help Page
Old 06-06-2009, 12:36 PM
pslsnakes
F#%K JDM, USDM FTW
pslsnakes's Avatar
Very nice, and an extensive list of proper mods. It should sell no problem.
Old 07-17-2009, 05:42 PM
TAG
TAG's Avatar
The car is still available.
