2003 TL S Passanger side seatbelt
Has anyone with a 2003 TL Type S experienced or is experiencing the seat belt locking up? When the passanger side seatbelt locks up, I need to take it off slide it up and then down again.
I took the car to Acura and they replace the retractor and the problem is still there.
What could be the problem? I know that there was a recall for the 2002s but I would think that the problem was corrected on the 2003s.
Thanks,
Thanks,
chris is the devil
do you mean it locks up just when putting it on? You do know that when you pull all the slack out of the belt, it will lock the belt, and keep it from extending until you take it off and retract it all right? That a feature, but i think you have a different problem.
Lord Vader Moderator
If it doesn't not unlock after you let it loose a little and pull again, then obviously someting isn't right. Take it back to the dealer.
