h22 vtec problem
i have h22 on my 92 accord, but i dont have that problem. mayb ur vtec wire to the ECU is lose, or mayb ur oil pressure is low, check ur oil level and the oil pan for damage.
I missed Sean
1 Post
how so? and by kick in I am assuming you mean it just sounds like your engine is hurting in the top end
If the engine is cold, it won't engage.
If the engine is low on oil/has low oil pressure it won't engage.
you may have a loose wire or something as stated above
or you could be expecting an actual kick in the arse at the engagement point, which just doesn't happen
