2005 Acura RL- Sound system ground problem
The Car: 2005 Acura RL, with Bose, Nav, 6-disc In-dash Changer
Installed: 2 JL W7, Alphasonik amp, audio control epi-center, grabbed the signal off of the factory sub in the rear deck with a L.O.C.
The Problem: Low level noise that plays through the subs, it varies with engine RPM only between 1000-2000 rpm's. And the noise will go away when any door is opened. It doesn't matter if the trunk is open. Car must be running. The noise will usually go away if it's driven a short distance(50-100ft).
Any help will be great!!
