Shocks Versus Struts Versus Dampers - Shakedown
Administrator ☂
Find out how to tell the difference between shocks and struts here.Some Hondas have shocks up front, like the'92-'95 Civics, '94-'01 Integras, the TSX, and, well, a lot of Accords, but some actually have struts, like the RSX and '01-'05 Civics. Although both control and dampen spring oscillations and therefore can both be referred to as dampers, they are different and, as such, shocks should never be called struts or struts shocks. To be sure, struts actually locate suspension components whereas shocks are simply bolted to the lower control arm assemblies by means of forks or brackets. Unbolt a strut and the knuckle drops to the ground. Unbolt a shock and, well, not much happens. So next time you talk about your '93 Civic's front strut tower bar, consider the fact that your Civic doesn't actually have any struts.
Photo Gallery: Shocks Versus Struts Versus Dampers - Honda Suspension - Honda Tuning Magazine
Read More | Digg It | Add to del.icio.us
More...
More...
