Swap *Pics* - not 56k friendly
Old 12-07-2002, 06:54 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Default Swap *Pics* - not 56k friendly
As you requested
I just took these tonight about 5 minutes ago.
I'll take pics of the whole car during the day sometime...
Enjoy! :thumbup:
Old 12-07-2002, 06:57 PM
Paulll
Hail Bent
Paulll's Avatar
thanks man, that is so sexy! how much did that set u back?
Old 12-07-2002, 06:58 PM
westcoaststyle
About $10k
Old 12-07-2002, 07:00 PM
Paulll
Hail Bent
Paulll's Avatar
Originally posted by westcoaststyle
About $10k
:jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
Old 12-07-2002, 07:01 PM
westcoaststyle
ENGINE
Block
B18C1 Swap
SRP 9.5:1 pistons
Eagle "H" rods
ARP rod bolts
Total Seal rings
Cylinders bored 0.0010 over
Honda green & brown rod bearings
Summit Racing main bearings
Balanced & blueprinted crank, rods, pistons, flywheel, clutch, and crank pulley
Unorthodox racing crank pulley
ACT XT-SS clutch
B&M short shifter w/ Energy Suspension bushings
Clutchmasters 7.5lb flywheel
Acid dipped block
Full new conversion kit (bottom end gasket set - Summit Racing)
DC Sports 4-1 cc LS header
Custom 2.5" exhaust piping to an Apexi Dunk universal (currently)
Will be going to a dual N1 setup shortly (I have the mufflers now)
AEM CAI w/ bypass valve
Venom dipstick (polished)
DC Sports battery tie-down (polished)
Energy Suspension motor mount inserts
Head
Port matched on the intake side
3 angle valve job
Decked
ARP head studs & nuts
Acid dipped & glass bead blasted head
All new head gasket/seal set (OEM Honda)
OEM head gasket
JDM ITR red valve cover
DC Sports wire cover (polished)
Magnacor 10mm plug wires (red)
MSD Blaster external coil w/ distributor cap
Fuel
AEM fuel rail (red)
AEM high flow fuel filter (silver)
Venom injectors (10% over stock cc)
ITR FPR
GSR throttle cable and bracket
Misc
P52 '94+ Del Sol DOHC VTEC AC mount (so I could keep my AC)
P72 OBD1 ECU
All mounts and caps are painted flat black
Old 12-07-2002, 07:06 PM
Paulll
Hail Bent
Paulll's Avatar
When are you going to Dyno it?
Old 12-07-2002, 07:08 PM
westcoaststyle
After I break it in. I've only got about 300 miles on it right now. It's actually gotten faster since the first few times I've driven it. It's so much fun and I love knowing that I did it all by myself.
Old 12-07-2002, 07:29 PM
Max Power
Buff Member
Max Power's Avatar
mann, i know i'm gonna sound like an idiot if i start saying this . ..
it looks like you have a 9.5:1 compression naturally aspirated motor. . . does that seem a little tame? you spent a lot of money and all i can see you with is pretty much a brand new engine? (prepares for flame onslaught)
Old 12-07-2002, 07:31 PM
westcoaststyle
lol.. I'm not gunna flame you man.
Built for turbo. Will be putting full Drag III kit on in March (or so).
Old 12-07-2002, 07:43 PM
The G2 Racer
Want Boost!
The G2 Racer's Avatar
That looks f**king sick bro. I can't wait to have my B16A sitting between my fenders.
