exhast question!!
exhast question!!
hi, if i changed the muffler, should i change the resonator and the pipe too?
i think my resonator is about time to be replace, cause its making vibration sound inside when i step on the has, so is it necessary to replace?
also if i just replace the 2.25" pipe, resonator and muffler after the cat, like the mid section to the end, is it good enough?
by the way, i have a 98 civic ex!!
thanks you!!
thanks you!!
Still here... sorta...
If you just change your muffler, you will essentially only be changing the sound of your car. I had the muffler shop make a full catback exhaust because usually universal mufflers come with 2" pipe coming out of them and your stock piping is smaller than that.
I'd go catback if I were you and just have them put a resonator inline.
Originally posted by jordan88
so, should i put a resonator on it or just leave it as straight pipe?
