very leaky v-tech soleniod
Old 09-21-2008, 04:24 PM
bbrcracer
bbrcracer's Avatar
Default very leaky v-tech soleniod
i ordered new the o ring and gasket. the valve cover gasket is only couple months old,water pump and timing belt also. is there anything i should get to fix this problem.
also i need to replace the water hoses under the intake manifold...they arecovered in oil...how hard is that, and what do i need to replace when i remove the manifold. any help with this will be great!
Thanks.
Old 09-21-2008, 09:01 PM
Snoopy
been there done that
Snoopy's Avatar
you probably need a new cam seal
