FS Street Ported RX7 Turbo.....TO4E,Momo,RTEK Must see!!
1987 RX7 Turbo
for sale - $4,000
* 132,000 miles on chassis
J-Spec 13B turbo has less than 10,000
Email - Lsvtect96@hotmail.com
Location - Northern VA
Phone number - 540-623-9483 ask for aaron
*has a cooling issue...dont know what it is (sold as is)...
compression test came out 90psi across both rotors...
No water/coolant in oil...doesn't burn oil either...
50psi of oil pressure at idle and 75psi at full boost
12.1 on wideband at full boost
NOW HAS Rtek Stage 2.1 ECU upgrade
NEW TUNE 386RWHP 311 torque at 16psi!!
ENGINE Street Ported 13BT (S5 Spec)
w/ T04E Turbo and S5 exhaust side
Blitz front mount
Mazda Trix Intercooler piping
HKS BOV w/purple insert
Greddy throttle body elbow
New OEM Mazda Irons, Housings and Rotors
new 2mm Mazda Apex Seals
Racing Beat Aluminium Flywheel
Royal Purple 20w50 Synthetic Oil only!!
FUEL SYSTEM
RTek 2.1 Stand Alone w/base mapping
550cc Primary Injectors
1600cc Venom Secondary Injectors
Walbro 255 Fuel Pump
AEM FPR
Suspension and Drivetrain
MOMO rims with street slicks in the rear
K2RD Coilovers w/KYB AGX Shocks
K2RD Camber Plates
Mazdaspeed Rear Strut Tower Brace
Racing Beat Sway Bars
Racing Beat Sway Bar Links
Powder Coated Sub frame and Suspension
Mazdacomp / Mazda Suspension and Sub frame Bushings
Installed but not in pictures
-Double alternator pulley
-Stock radiator clutch fan and fan shroud
- New electric fan
Exterior 7/10
Interior 8/10
