94-01 Teg Shifter in 96+ Civic???
Old 12-05-2002, 08:16 AM
bizkit
bizkit's Avatar
Default 94-01 Teg Shifter in 96+ Civic???
I've heard before, (I think), that putting a 94-01 Integra shifter in a Civic gives for a smoother feel, somewhere in between the stock Civic shifter and a short throw. Is this true and does it bolt right up? Thanks.
Old 12-05-2002, 10:51 AM
SpeedRacerEX-R
SpeedRacerEX-R's Avatar
The integra shifter won't fit in the civic linkage.
Old 12-05-2002, 11:04 AM
94civicEX
I got worms.
94civicEX's Avatar
My buddy put his short shifter from his 6th Gen. Si into his 99 GS-R, added a couple washers and it worked great. So, I donno what he did?
99 Integra GSR
06 TSX
duck squad member #00003
Old 12-05-2002, 11:37 AM
Outxider
X-Motoring
Outxider's Avatar
in order to fit a stock gsr shifter in a civic, u need to grind down the piece that the bolt goes thru to hook up to the linkage. i had to grind down bout half inch i believe and then pull the bearings out of my stock civic shifter and put em in, inorder to use the shifter. cuz the gsr linkage is different then that of a civic, so u need to grind down the gsr shifter to fit.
late
Old 12-05-2002, 12:40 PM
SpeedRacerEX-R
Yeah, you can use ingenuity. Or just order the right part.
