steering problems
Old 12-04-2002, 12:01 PM
etmoron
Moron Member
etmoron's Avatar
Default steering problems
right behind the drive axles , what seems to look like a cv boot is ripped . i think its hooked on to the steering wheel , when i move the steering wheel left or right , makes a scratchy lound sound , like metal to metal . got any clues on what it is ?
Old 12-04-2002, 12:13 PM
HLD_Civic
se7en
HLD_Civic's Avatar
You're cv joints (inside the boots) are at the end of your drive axles.
Old 12-04-2002, 12:51 PM
Nelson
Administrator
Nelson's Avatar
That is your steering, mine is ripped too. Last I checked it's expensive to fix the whole thing. I think you can change the boot though (similar to your CV-joint)
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 12-04-2002, 06:07 PM
etmoron
Moron Member
etmoron's Avatar
i just checked it just now after i talked to someone the knew about kind of , he said check you p/s fluid , if its low then it might be leaking thru the sealant in the steering thing. i check and its almost all out, but i checked if the cv boot thingy wa very watery but its was just a lil greasy and dirty and black .
Old 12-04-2002, 09:26 PM
Cashis EG8
Registered Rota Dealer
Cashis EG8's Avatar
Sounds like you need to replace the CV boot. Relatively cheap part.
