my rear quarter panel is rusting
Old 12-02-2002, 07:35 PM
derf
Spec5
derf's Avatar
Default my rear quarter panel is rusting
its rusting from within... as it is bulging underneath... its also starting to rust right above where the rear bumper ends and meets the body.... any help as to stop this from spreading? there is also a small bulge above one of the outer tail lights....
i hate it when my car starts to look old
did I mention the clear coat is falling off in 5 places?
Old 12-02-2002, 07:39 PM
asiandoood
sancho on the sizzide!
asiandoood's Avatar
rust to a car is like cancer to humans.
if it is rusting under the paint, you may want to take it to a body shop and have them replace the panel. rust will not stop...it will just keep spreading if not treated. they have rust convertors that you can apply to the surface, but I dont know how well those things work.
Old 12-02-2002, 07:49 PM
derf
Spec5
derf's Avatar
i'm assuming u know what I"m talking about... how its bulging out...... looks like a bubble under the paint.. just hard.
Old 12-02-2002, 08:01 PM
SW20 MR2
SW20 MR2's Avatar
Welcome to the world of Honda. In my area, it's nearly impossible to find an EG Civic without the same thing that you have. Your only option is to cut the rusting metal out and re-weld a piece of sheetmetal back in.
Old 12-02-2002, 08:30 PM
derf
Spec5
derf's Avatar
this happened recently too....poo!
Old 12-03-2002, 03:33 AM
str8edgexx
str8edgexx's Avatar
:werd: That happens to pretty much all older Hondas you see (in areas where it snows and they use salt). You should see my Dad's old '89 Accord....pieces of it fall off when you close the door. This is just a sad reality that many 5th gen guys are going to start seeing in the next few years as the cars get older. From what I have heard, as SW20 MR2 said, the only way to totally cure it is to weld on a new piece of metal. I know Fuji did something to his car to create a drainage passage to try to prevent this from happening....maybe talk to him.
Old 12-03-2002, 04:32 AM
madlow
madlow's Avatar
I just had mine fixed so it wouldnt get worst through the winter. Now my car looks brand new again.
Old 12-03-2002, 09:16 AM
derf
Spec5
derf's Avatar
how did u fix it?
Old 12-03-2002, 09:43 AM
madlow
madlow's Avatar
Originally posted by derf
how did u fix it?
brought it to a body shop.. The sand blasted it and repainted the area. It cost me $50(which is extremely cheap) and you cant even tell it was ever done, no matter how close you look.
Old 12-03-2002, 09:53 AM
derf
Spec5
derf's Avatar
maybe i'll tell them to do that when they repaint my trunk.... some fawker keyed the entire length of my trunk
