'97 GS-R Oxygen sensors
Apathy Kills
Yes. It does.
But before you start throwing parts at the problem blindly, what's going on?
Assuming the Check Engine Light has illuminated, have you pulled the error codes?
If so, what are they?
Unfortunately no .. haven't done that. My father is going to work on it and we don't know anything about engine codes, or how to pull them.
My "check engine" light has been steadily lit for a month, but no real symptoms (except a somewhat rough idle). Then last week as I was accelerating to merge onto the highway, the light began flashing and acceleration was difficult. It will drive at slow speeds okay, but I have it parked waiting for repair.
Naturally, this couldn't be a worse possible time for us, financially ... otherwise I'd take it to a mechanic.
Apathy Kills
Do this first. Otherwise, you are wasting time and money by guessing at the problem. The On-Board Diagnostics system is designed to expedite repair by giving you detailed information; use it to your advantage.
My "check engine" light has been steadily lit for a month, but no real symptoms (except a somewhat rough idle). Then last week as I was accelerating to merge onto the highway, the light began flashing and acceleration was difficult.It will drive at slow speeds okay, but I have it parked waiting for repair. ...
Come back to us once you have the CEL codes in hand.
Also, which model trim is your 97 Integra?
It's a GS-R. You have 2 sensors, one before the cat and one after the cat. Scan the codes and make sure it actually is the O2 sensor/s failing otherwise you're wasting time and money. If it IS one of those sensors, spray them liberally with PB blaster(this works the best) a few days before the replacement, this will help break them loose.
