HELP! 5th gen EX won't start!
Old 12-01-2002, 10:49 PM
OneToughCivic
OneToughCivic's Avatar
Default HELP! 5th gen EX won't start!
Whats up - I haven't posted in a while, got rid of broadband and I'm back on dial-up for a while, it kinda makes me want to cry, so I don't go on the net as much anymore...
ANYWAYS:
When I crank my car, it turns over but won't start. Then when I stop cranking and let go of the key, I can hear a pop from the intake. I took it to Honda, and they told me the timing was off. So I had them fix it, and guess what? Still doesn't start. Have any of you heard of anything like that? After I've been cranking for a while, I can smell gas under the hood, so I know it's getting fuel, just no spark. What do you think it is? Ignitor? I know the plugs aren't fouled out, so that's out of the question. What else could it be? Any ideas please help! Thanks in advance...
Old 12-01-2002, 10:51 PM
frank
frank from canada
frank's Avatar
wait a second, so when they "fixed" it, did it start? or did you just roll it back home?
Old 12-01-2002, 11:01 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
It could be anything with the dist... Not a fun problem to search out. Start by swapping the ignitor with a friend's. Almost all Honda ignitors are the same. Other than that, the cap and rotor in good shape? Wires all secure?
Old 12-01-2002, 11:14 PM
OneToughCivic
My friend has an ignitor from a 6th gen EX (D16Y8), and mine, of course, is a D16Z6. Chances are they are pretty close right? I'll try that.
Old 12-01-2002, 11:15 PM
OneToughCivic
it started once, and never ran again. I don't know how they did it.
Old 12-02-2002, 06:36 AM
Nelson
Administrator
Nelson's Avatar
Tell them that it doesn't work again... they should fix it. Check the ignition coil...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 12-02-2002, 01:55 PM
derf
Spec5
derf's Avatar
my bet is on the ignition coil... depending on what year, i know 92 and 93 had problems with the ignition coil...
Old 12-02-2002, 05:46 PM
OneToughCivic
mine is a 95
Old 12-02-2002, 05:54 PM
derf
Spec5
derf's Avatar
well, same gen. replace it and see what happens. if it won't turn over, no need keep trying it and flood it (what i did )
www.thepartsbin.com has 'em cheap. maybe replace the cap and rotor while you are at it... they aren't expensive.
Old 12-02-2002, 06:23 PM
OneToughCivic
so what's the difference between the coil and the ignitor? people are telling me the ignitor is bad. what are the functions of either part?
in the words of pat from SNL:
"i'm so confused"
