How well would a 215/50/15 fit on a 6.5"rim?
Old 11-30-2002, 09:06 PM
Mike99
U.S. CoastGuard
Mike99's Avatar
Default How well would a 215/50/15 fit on a 6.5"rim?
215/50/15's and 195/55/15's have almost exactly the same height and my Rota Subzeros are 6.5" wide I believe. I was wondering if they would rub? Fit correctly on a 6.5" rim? And what if I drop my car upto 1.5"? Thanks
Old 12-01-2002, 04:26 AM
inspyral
のんびり~(´ε`)
inspyral's Avatar
205/50 looks a bit fat on a 6.5" wheel. I would imagine 215 to be even more balloon-y. Depending on the offset of the Subzeros, which is probably either +40 or +38mm, and how much of a drop you're running, you'll have a pretty good chance of rubbing, at least at full steering wheel lock, and possibly over bumps. At 1.5" with no camber correction and a +40mm offset, you could probably get away with running 215s.
Here's an idea of what 205/50 looks like on a 15x6.5" wheel:
Old 12-01-2002, 06:12 AM
Mike99
U.S. CoastGuard
Mike99's Avatar
That does look a bit ballooney. Does the 205 have an even contact patch? I was wondering because I know stock ITR rims and stock SI rims are 6" wide and have 195/55/15's on them. 6-1/2" rims are about 8.3 percent wider than 6", and 215mm is 10.3 percent wider than 195. I figured it would be close, but those 205 look a bit fat on that 6.5" rim. Thanks for the pic, do you have any from the front or back view? Thanks
Old 12-01-2002, 06:44 AM
randomtask77
Wanderer
randomtask77's Avatar
Inspyral, wouldn't the manufacturer's design also be a factor? I had the Azenis on the 15" steelies and they didn't look balloon-y on 205/50/15's. Now I have the Ziex 512's and they don't look like that either. I'm just guessing that is how Kumho makes their tires and not necessarily other tire manufacturers....
Old 12-01-2002, 10:30 AM
inspyral
のんびり~(´ε`)
inspyral's Avatar
If you look at most tire manufacturers, the recommended wheel width for 205/50/15 is 6.5" and the range goes from about 5.5/6-7". The range for a 215/50/15 tire is 6-7.5", so you could fit it on a 6.5" wheel and it should be alright.
I don't have any direct front/back pics, but this one is slightly angled:
That could be a possibility. A stiffer sidewall will "balloon" less at the same tire pressure, so maybe the Kumhos have softer sidewalls.
Old 12-01-2002, 12:55 PM
Mike99
U.S. CoastGuard
Mike99's Avatar
Are those the Kumho Supra 712's? I can't tell from the pic. The 711's are available in 215/50/15, I here there a bit stickier in the dry but a little worse in the rain. I need traction bad, so I think I'll try the 215's next time I get tires:thumbup:
Old 12-02-2002, 09:18 AM
inspyral
のんびり~(´ε`)
inspyral's Avatar
yup
Old 12-02-2002, 04:54 PM
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
215/50x15" will slow your car down ALOT. Plus being on a 6.5" wheel is not optimum. Your turn-in and overall handling will prolly decrease in feel and quickness. A ballooning tire doesn't have a great characteristic as compared to a tire that sits flush with a wheel.
For a 215 tire you should use a 7.5" wide wheel. A 205 is good for a 7" wheel. And 195 is good for a 6.5" wheel.
I've seen 205/50x15" Azenis on an Si wheel 15x6" and it's bulging out.
Autocross Help Page
Old 12-02-2002, 07:16 PM
FourthGenHatch
I'm RICK JAMES, bitch!
FourthGenHatch's Avatar
I have 6.5'' wide 15s with 205s and they don't ballon.
Old 12-02-2002, 07:18 PM
Nelson
Administrator
Nelson's Avatar
Bubbly
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
