Heater not blowing hot..
Old 11-29-2002, 11:06 PM
Din
Din's Avatar
Default Heater not blowing hot..
My 2000 Civic EX doesnt blow hot when the heat is on. Anyone know what is wrong?
Old 11-29-2002, 11:08 PM
WideBodyEK
Stage 3 Modified
WideBodyEK's Avatar
does your temp gauge work??? if not then its your thermostat,...if it does work,..then it could be your heating core
Old 11-29-2002, 11:13 PM
Din
Din's Avatar
temp gauge works
car warms up like normal.
how can i check the heating core
Old 12-01-2002, 08:16 PM
Hondaman
Black Pearl
Hondaman's Avatar
You should have a valve that opens and closes under your hood to allow the hot coolant to go into the heater core. Open your hood and look for that valve. It should be about the size of a baseball and inline with one of the 5/8 inch size hoses that goes to the firewall. Have a friend move the lever on your dash back and forth to make sure the valve is opening and closing. If it's not, it's probably a broken cable. If it is, it's probably a pluged heater core. Good luck!
Tom
Old 12-01-2002, 10:55 PM
Din
Din's Avatar
Isnt the 2000 model electronic? I took apart the ac controls to install a radio and it has plugs.. I know the 96-98 model had a lever that had some kinda rod connecting to it.
Old 12-01-2002, 10:58 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
Either way, the heater core will be sticking out of the firewall, and that should be the problem.
Old 12-01-2002, 11:00 PM
Din
Din's Avatar
Ill check tomrrow.
