How to change Door Lock Actuator
you have to pull the latch to replace the actuator it's less then an hour for a pro but theres alot of plactic clips that lock in to the outside handle and easy to break also the lock cylinder renforcement bracket makes the clip hard to get at or try and loosten the latch and replace w/o removeing..
Not sure if you can follow this link, but it is on this site. Pretty detailed instructions.
https://www.honda-acura.net/forums/s...=actuator+lock
I also need to replace this part. Does anyone know of a good supplier?
