FS: '95 LS-T 4 door civic
Old 08-15-2008, 06:14 PM
civicduty
civicduty's Avatar
Default FS: '95 LS-T 4 door civic
* Name: David Willis
* Means of Contact: pm or 336-554-0008
* Vehicle Year/Make/Model: 1995 honda civic 4 door
* Miles:190k on body 65k on motor and trans
* Price: 7500.00 or obo
* Title: Salvage or Clear? clean and in hand
- Interior:8/10
blitz turbo timer
avital 4400 alram with remote start and pager
jdm console houses 5 gauges
autometer elec. oil pressure
autometer elec. water temp
autometer elec. fuel pressure
aem uego wide band
autometer boost gauge
new door inserts
new trunk false floor
rear deck under cover
- Exterior: 7/10
amber corners
1/2 clear 1/2 red tails
8k hids
- Stereo & Nav:
alpine 9886
jl 4 channel
alpine typer components and seprates
dynamat front doors
- Suspension: itr 5 lug
gsr upper front strut bar
no name rear upper strut bar
no name c-pillar sturt bar
drop zone struts
skunk2 springs
ss brake lines
cross drilles and slotted rotors
wicked front upper adjustables control arms
wicked lower adjustable in the rear w/ wicked lca's
- Wheels: rsx wheels with brand new nexxens 205-40-16
- Egine: LS-T 2000 b18b and ls trans
nology spark plug wires
stage 2 clutch masters clutch
fidanza 8lb fly wheel
skunk2 pro series intake mani
hondata inatke mani gasket
avid billet motor mounts
hondata s200/b
walboro 255 fuel pump
Brand new turbonectics t3/t4 62-1 63 trim
full race equal length manifold
3" full race down pipe
fmic
rfl bov knock off
tial knock off waste gate 44mm
10lb tial spring
dsm 450cc injectors
engine damper
gas hood shocks
morso oil pan
ss sending and return oil lines
dss stage 2 axles
typer r crank pulley
new timing belt
new water pump
new clutch slave on tranny
polished alum. radiator
polished alum. over flow tank
mild wire tuck
semi polished block and tranny
Vibrant full 3" tubo back exhaust
3" elec cut out
new tb gaskets
new valve cover gaskets
new plugs
honda tranny fluid
mobil 1 10w30 and honda filters is all that goes in it
The Good:
It has been tuned by mark up at turbo tunes on 10 lbs daily driven
250whp 200 ftq runs real good,
The Bad:
Time to let her go, needs some paint clear coat is peeling,
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
