How do you check timing on a 5th gen
Old 11-26-2002, 11:34 PM
derf
Spec5
derf's Avatar
Default How do you check timing on a 5th gen
I have a timing gun at home we used for our other cars. Now I've never checked the timing on my 5gen so I'm wonderni how u do it. On my old hooptie, you clipped on wire ont the ignition coil, one on the first igntion wire.... but on a 5gen the ignition coil is inside the distributor... so what do you hook it on to?
if you've done it... it would help me a great deal as to how u did it
Old 11-27-2002, 02:21 AM
SpeedRacerEX-R
SpeedRacerEX-R's Avatar
There should be a + and - battery clips and a spark plug clip. Put the plug clip on the #1 plug wire and the other two clips on the battery and point it at the crank pulley.
Old 11-27-2002, 02:44 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
that's right. If you have a stock pulley, there's a red mark on there that you put in line with the marks on the lower timing belt cover. They look like the sights on a gun.
You loosen the 3 12mm bolts on the distributor and rotate the distributor to time the engine. It's really easy.
Old 11-27-2002, 09:57 AM
derf
Spec5
derf's Avatar
hmmm we always cliped it onto the igntion coil wire... i'll look into it this weekend
Old 11-27-2002, 10:07 AM
westcoaststyle
No man, it's your plug wire #1
Old 11-27-2002, 10:14 AM
derf
Spec5
derf's Avatar
maybe i just rememberd wrong... definately one plug on spark wire #1, one on ignition coil, and one somwehre else... i guess i remembered wrong...
Old 11-30-2002, 10:57 AM
derf
Spec5
derf's Avatar
okay... now where is the mark?
i foudn the red mark, and the two non colored marks on the fly wheel.... but where is the reference point?
any websites that would help are appreciated!
Old 12-01-2002, 11:16 PM
SpeedRacerEX-R
It's faaaa faaaaaaaaaaa south!
It's about 14 degrees to the right of the red mark.
Old 12-02-2002, 07:47 AM
westcoaststyle
The mark that you time against is on the lower timing belt cover. If you're looking down on it, it's to the right of the motor mount. It looks like gun sights.
Do a search on google or something for a site... OR buy a Haynes or something...
Old 12-02-2002, 01:54 PM
derf
Spec5
derf's Avatar
thanks for the help, i figured it out..... i was going to buy a helms... but i just need to find out right then and there... since i have no manual... thanks again!
